Discussion topic: Broadband not working
Message posted on 08 Jul 2026 02:29 PM
Stopped working around 14:15 ish but broadband checker says no issues
Message posted on 08 Jul 2026 02:30 PM
Re: Broadband not working
@rossgammell
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
