Discussion topic: No WiFi
Message posted on 08 Jul 2026 02:00 PM
No WiFi
What to do when WiFi isn't connecting
Message posted on 08 Jul 2026 02:32 PM
Re: No WiFi
@Sue5661
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
