Discussion topic: No WiFi
This message was authored by: S+J+Burke66
No WiFi
I have no WiFi
Re: No WiFi
@S+J+Burke66
Even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
