4
This discussion topic has been answered Discussion topic: FULL FIBRE SPEED
This message was authored by: Nick296
FULL FIBRE SPEED
Hello, I have just had Fibre Broadband fitted (300mb/s) downstairs is great super-fast upstairs useless I thought fibre was the way to go I moved over from EE didn’t have this problem without fibre, any help would be gratefully received, TIA.
Avatar for Nick296
This message was authored by: Nick296 Answer
Re: FULL FIBRE SPEED
Thank you is that an additional cost
Hi @Nick296
The Fibre technology used has no affect on how the WiFi performs in your home, this is down to local conditions such as router, home construction/layout, local devices & interference.
Speed is always going to be best next to the router, and then taper off as you get further away. You may want to look at getting boosters from Sky to improve coverage in certain rooms.
I am NOT a Sky Employee
Avatar for Nick296
@Nick296
If you dont already have WiFi Max, then yes
Avatar for Nick296
Just looking at extra £6 a month surprise I thought that it would be include not sure to bother or get some WiFi extendors
