Discussion topic: No WiFi
Message posted on 26 May 2026 06:47 PM
No WiFi
My router has completely shut down. I switched it on and off, nothing. I unplugged everything and switched it back on; all the green lights came on for about 30seconds then nothing again. I've run the service checks and it says everything is fine.
There's a few other posts about this issue so it seems like a widespread problem! Is it the heat, maybe? Would that affect routers / WiFi? Or is there an issue at Sky?
Message posted on 26 May 2026 07:24 PM
Re: No WiFi
@LaurenM212 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
