Discussion topic: no wifi
Message posted on 26 May 2026 07:28 PM
no wifi
the wifi box is on, the power light is on but it's not working even though the app diagnostic check says it is
Message posted on 26 May 2026 07:32 PM
Re: no wifi
@emilyfwright
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
