Discussion topic: No WiFi
This message was authored by: HJ8
No WiFi
We lost wifi yesterday from 2pm approx until 11.30pm and the same thing has happened today at 6pm. We have no WiFi which means no TV, no phone line, unable to use laptops for work and school purposes.
Re: No WiFi
@HJ8
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
If you’re still having problems you may need to contact Sky to report it.
