Discussion topic: No Internet connection
This message was authored by: Lnug
I have no Internet connection there's no green light on router box
Re: No Internet connection
@Lnug
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
@Lnug If it has just happened then give it some time but run the link below, takes at least 1 hr to show up!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
