Discussion topic: Broadband keeps dropping every 10 minutes or so
Message posted on 22 Dec 2025 06:37 PM
Have rebooted the router and run skyschecker which reports no problems in the area. But I have a problem with the broadband
Message posted on 22 Dec 2025 06:41 PM
Re: Broadband keeps dropping every 10 minutes or so
Message posted on 22 Dec 2025 06:46 PM
@davemag1
Use that link to check to see if there are any broadband issues or outages nearby ~
