Discussion topic: No WiFi
Message posted on 14 Oct 2025 08:00 AM
No WiFi
WiFi is not connecting. I have turned it on and off but still not working.
Message posted on 14 Oct 2025 08:08 AM
Re: No WiFi
@Stacy19
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
