Discussion topic: Wifi and phone
This message was authored by: Shawy1
Wifi and phone
Wifi not connected and phone problem
Re: Wifi and phone
@Shawy1
Presumably you're referring to your landline phone there and not a mobile?
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
If you’re still having problems you may need to contact Sky to report it.
Avatar for Shawy1
Re: Wifi and phone
Hi thanks, sky have just sent an email saying that we have had an internet outage. Looks like that was the problem
ta
shawy1
