Discussion topic: No WiFi
This message was authored by: Hannahbrowne
No WiFi
Hi the router and connection test online says our connection is good but we have no WiFi
Re: No WiFi
@Hannahbrowne
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
▪️I AM NOT A SKY EMPLOYEE ▪️
