Discussion topic: No WiFi
This message was authored by: CJBK
No WiFi
Wall socket shows a green light a red light and a flashing green light
hub shows 2 green lights and a red light
Re: No WiFi
@CJBK
This explains the lights on the hubs:
Try running the line test here:
If this is of no help give Sky a call to report it to them.
Re: No WiFi
@CJBK If it is the LOS on the wall with the RED light then connection issue between the Home and Exchange and no light on the Fibre.
As you where advised see if the service checker flags up anything that sky may be aware off as an area wide fault!
