Discussion topic: No wifi
Message posted on 19 Jul 2025 10:01 PM
No wifi
Hi All
It seems the only way to get a Sky engineer out to fix a problem which the can't fix remotely is to ask you guys how to fix my non working WiFi. Ive done the standard robot engineer things like turn it off and back on, disconnected everything and reconnect it back again. Yet it appears that's not fixed anything. God forbid i could actually speak to someone. So if you do have exceptional skills that the IT robot doesn't have then you might be able to help. I don't expect you to do it for free, and I will recommend you get 50% off your next Sky bill. Which i think is only fair seeing as your doing their job for them.
Many Thanks
Message posted on 19 Jul 2025 10:33 PM
Re: No wifi
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 20 Jul 2025 08:27 AM
Re: No wifi
@Muggedbysky You also need to supply all the useful information that is required for the Forum to have any chance that is what service are you connected too, fttc or fttp (copper/Fibre) type of sky modem you are using, anything you see when the fault occurs so some links below to get started.
