Discussion topic: No WiFi
This message was authored by: Jadebj
No WiFi
Our internet is not working. Our phones tv and laptops are not able to connect.
Re: No WiFi
@Jadebj
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
