Discussion topic: no intern
This message was authored by: Janicea94
no intern
no Internet connection light not on the router tried switching everything off. no Internet on on phones etc
Re: no intern
@Janicea94
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
