Discussion topic: WiFi not working. Orange light
This message was authored by: MattCockett
WiFi not working g
Re: WiFi not working. Orange light
@MattCockett
If it's happening at the time you've posted it's possibly maintenance related. This is done overnight to minimise disruption as most customers are asleep. If it's not back up by the morning use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Any Openreach visit that’s required is likely to be delayed due to the disruption from the recent storms.
