Discussion topic: No WiFi
Message posted on 24 Jan 2025 04:00 PM
No WiFi
Your checker reports no issues, but no WiFi available. Obviously in a red alert area but surely you would know if there is an issue?
Message posted on 24 Jan 2025 04:18 PM
Re: No WiFi
@KirstB2
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
The lines will be particularly busy at present due to the damage and disruption caused by Storm Éowyn.
