Discussion topic: No WiFi
This message was authored by: SoniaMarie
No WiFi
I have run tests and restarted my hub, unplugged and plugged back in like suggested, but still no WiFi, although the checker is saying everything is OK? I was watching a film and it just cut off about an hour ago now. My WiFi on my phone says connected without internet? Thanks.
Re: No WiFi
@SoniaMarie chack the lights on your hub and use this trouble shooter https://www.sky.com/help/articles/hub-lights-explained-start
This message was authored by: HiHowAreYa
Re: No WiFi
Your tests indicate it's not a WiFi problem, you've lost broadband/internet.
You'll need to phone sky
(removed)
And tell the automated system you have a ONLINE FAULT which will get you through to a human tech support.
Moderator note: Removed phone number.
Re: No WiFi
Your tests indicate you don't have a WiFi problem, but a broadband/internet fault.
Phone sky and tell the automated service you have a ONLINE FAULT which will get you through to tech support.
