3
This discussion topic has been answered Discussion topic: No WiFi: need to work:
This message was authored by: Anton12
Hi all,
My router has started dropping out this morning and I can't work because the signal.is not working. My router's lights are as follows: solid green, flashing orange and keeps cutting out, solid green, solid orange. Gemini has confirmed that this is likely to be an issue with the external cabling or the terminal box - and now I don't know what to do. I am a data analyst and need to be able to work. Can you help please?
Thanks and regards,
Anton.
This message was authored by: GD1 Answer
Re: No WiFi: need to work:
@Anton12  Regardles of what Gemini says poleae follow the steps here:  First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@Anton12
It's worth adding that Sky broadband discussed here is a domestic service and whilst Sky are apparently fine with its customers working from home using it for this purpose they won't receive additional or quicker support.
No terrestrial ISP can guarantee uninterrupted service: the topology of the national cabled network makes that completely impossible.
Where a connection is critical, it's worth considering providers which offer automated failover to cellular data.
