Discussion topic: No wifi
Message posted on 26 Jun 2026 10:06 AM
No wifi
My Internet has not been working since 19:00 last night (25/06/2026) I woke up this morning and still no joy. The Amber light is on the router and I have tried all trouble shooting ideas.
Message posted on 26 Jun 2026 10:09 AM
Re: No wifi
@Lisa498
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
