Discussion topic: No WiFi AGAIN
Message posted on 25 Mar 2025 12:55 AM
No WiFi AGAIN
No WiFi AGAIN!!!
I need this problem rectified asap
prices going up but service not working properly.
sat watch tv, nothing moved or changed and wifi goes off, followed all steps but cannot get it working.
all online tests via app show working but it is not!!
Message posted on 25 Mar 2025 05:14 AM
Re: No WiFi AGAIN
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Hopefully it'll be back by 0700. If not use the below link to check to see if there are any problems or outages nearby
Message posted on 25 Mar 2025 10:12 AM
Re: No WiFi AGAIN
I can't my Mobile data to work
