Discussion topic: Wifi drops
This message was authored by: Marky7248
Wifi drops
Hi I seem to have drop outs at times when on work teams Calls. Everything looks connected but at times it drops out. I have an older sky q booster. Is there maybe a new booster that I need ?
Re: Wifi drops
Hi @Marky7248
Could you please let us know which Router & Booster you have
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
I am NOT a Sky Employee
Avatar for Marky7248
Re: Wifi drops
Hi I have a sky max router and a sky q booster
Re: Wifi drops
@Marky7248
The Sky Q booster is not appropriate for the Sky Max hub. You should be using Max Pods instead. These can be claimed from Sky if you have the WiFi max addon and you have either a WiFi blackspot in your home or one of your rooms is not getting the minimum WiFi speed stated on the WiFi Max agreement.
