Discussion topic: No WIFI again
This message was authored by: Derby71
No WIFI again
Why am I paying money for broadband and WiFi when it's never connected but when you do the speed check or connection test it always says everything is working and we all on data and you can't even watch tv
so annoying
Re: No WIFI again
@Derby71
Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
This should determine if there's an identified fault affecting multiple households.
