Discussion topic: No Ont box
This message was authored by Wombatsky This message was authored by: Wombatsky
No Ont box
Hi Folks, I'm a new Sky Broadband customer. I have no ONT box in the house, only a telephone connection box. The previous owner had Sky so it may the phone box is what I need to use. Would this be correct or do I need an ONT box? I've connected to the phone box with the Router. I have green light for power and WiFi but no Internet or voice. Today is my connection day, and I understand it can take up to midnight to connect Internet. What type of phone should I buy and can I phone out and receive calls, and where do I get my phone. Apologies for so many questions, am an absolute Sky newbie but computer saavie. Hope someone in Skyland can help.
Many thanks in anticipation.
Bill
Re: No Ont box
@Wombatsky
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Re: No Ont box
@Wombatsky
Could you enter your full address below and post the table and notes after removing your address from the image
Wombatsky
Re: No Ont box
No Joy, thanks. Address not showing. Will check later today
Re: No Ont box
Any normal analogue telephone handset or DECT base would be appropriate: what you don't want is a 'digital' or 'VOIP' phone.  By default you'd be provisioned on Sky Talk Pay as you Talk which accepts incoming calls but with rather a high pence-per-minute charge for outbound.
Wombatsky
Re: No Ont box Sky are on the case. Second engineer calli...
Re: No Ont box Sky are on the case. Second engineer calling tomorrow , 7th march, new fibre line and ONT box to be fitted. Watch this space.
