Discussion topic: No Internet connection
This message was authored by: Jill09
My Internet  is not connected.  Went off approx 1 hour ago I have had to use hotspot as I work from home.
I have switched it all off at the wall and rebooted it but it still only shows 2 lights out of the 3
Re: No Internet connection
@Jill09
HAPPY NEW YEAR
This message was authored by: Sandie64
Broadband has been down. It was down for over 24 hours in Gloucester. Had to wait until I got to work this morning to roll back data from piggy bank. Didn't come back until this afternoon which no idea what caused the outage. Maybe the same thing happening in your area.
