Discussion topic: No Internet connection
This message was authored by: andrea2610
Terrible Internet connection. Husband is working from home and connection keeps dropping out, sky TV stops working. On our phones it says we are connected no Internet. Sorts itself out then happens again. Been doing this constantly for days. Done all the tests on here and everything is fine apparently all green ticks, but I need to be using 4g to post this.
Re: No Internet connection
@andrea2610 Could you please post your router stats following the link below.
Avatar for andrea2610
Thanks for the  reply.  I can't access the router, it won't accept the default password or my WiFi password?
This message was authored by: Matty8119
Having exactly the same problem here in birmingham ... can't find a way of booking an engineer either
Seems to be a common thread from what I see on this forum. Sky, some customer service would be smashing.
I had virgin before and never had an issue. Might as well go back to them I think. I'm not paying every month for half the services I signed up for.
This message was authored by: Andyp11
Having the exact same problem every night for the past week!
its beyond the joke now, resetting the router does nothing.
@andrea2610 apart from showing your hub is connected at 56Mb/s those screens tell us nothing useful. The log in for your hub will require you to type admin as the usernams and either the word sky or the default wifi password on the label depending on the model of your hub. The link you need is at the bottom right of the status page.
