Discussion topic: No/Intermittent broadband for three days !
Message posted on 27 May 2026 05:06 PM
Tried to phone. No one will speak to me
on an actual phone! They want me to use internet to talk to them (I have none) had intermittent broadband for three days keeps dropping lights on/off have reset and followed all instructions.
Message posted on 27 May 2026 05:18 PM
Re: No/Intermittent broadband for three days !
@MuffinHeeler
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
