8
This discussion topic has been answered Discussion topic: No Ethernet from Hub
This message was authored by: Stephen106
Hi hope someone can help.
I had my sky Hub SR203 installed/activated on Friday, WIFI works great , but I cannot get the ethernet ports to work.
Tried on my laptop , I can see activity lights on the router and on the laptop but I cant get any web pages to open. Also the  windows shows the symbol for the ethernet connection as connected.
Also tried a cable to my TV and I get no connection on that also.
Phoned sky on Friday and they said it could be because I was using a Cat5e cable not Cat8 , even though I pretty sure they are backward compatible, I bought a Cat8 cable and it still does not work.
Can anyone help???
Avatar for Stephen106
This message was authored by: Stephen106 Answer
Re: No Ethernet from Hub
Strange, arrived home yesterday thought I would try the TV/Sky stream using the ethernet cables as I've tried before and this time everything worked 🤔😀
Thanks for the advice peeps 👍
That's very bad advice: Cat 8 is entirely unnecessary for domestic purposes (its primary role is patching between 10Gbs ports in server rooms) and Cat5e can easily carry gigabit ethernet traffic.
@Stephen106
One thing to check is that your computer doesn't have a fixed IP address in the range used by your previous ISP: that might explain the lit LEDs but no traffic.
I will thanks 👍
I will check thanks 👍
Thank you this was the problem on my work laptop, I forgot I set it to static IP to connect to some equipment .
Still cant get ethernet to connect to sky stream or  Tv(android), any ideas?
Yes, that would do it.
I'd suggest carrying out a network reset on each device.
This message was authored by: bonnie2019
ok, just had a fun few hours trying all sorts. wifi working but my pc wouldn't connect to the router, ok it did but i couldn't load any webpages. then i switched off ipv6, thats it done, i hate these little things
windows+r, ncpa.cpl, right click ethernet properties, uncheck ipv6
