Discussion topic: Internet keeps going off
This message was authored by: Lukecart
Internet keeps going off every other minute
Re: Internet keeps going off
@Lukecart
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
