Discussion topic: No Internet connection
This message was authored by: SandyReed
I have lost my Internet connection but when I run a test in the system it's coming up as ok.
Re: No Internet connection
@SandyReed it takes time fir tge service checker to pick up a line fault - it reports the last routine test and tells you when that was run - if your service is still down this morning run the service checker again as it should tell you if Sky are aware of a fault locally to you if tgeyvarent call tgem oncectge lines open around 8am so it can be checked out.
