Discussion topic: No Broadband despite Hub OL
This message was authored by: Douglas-Brown
Early hours 10 July broadband cut out and green light on hub. Switched off and back on and Hub working fine but still no broadband. Notice others too experiencing same problem. Not happy!
Re: No Broadband despite Hub OL
@Douglas-Brown
What's Hub OL?
When there are any broadband issues between midnight and 7am it could be essential overnight maintenance taking place. It is carried out at those times to minimise disruption and there is no advance warning provided.
See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
This message was authored by: Dsliverpool
Still down, tests not available, all lights on and helpline just extended close time to 8.30 from 8am - rubbish
@Dsliverpool
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
