Discussion topic: WiFi not working
Message posted on 10 Jul 2026 08:03 AM
WiFi not working
Hi my WiFi keeps going off for days at a time when the heatwave is here - I have turned it on/off it is not in direct sun/heat and the engineer came last week but it was currently working at this time so couldn't see the problem
Message posted on 10 Jul 2026 08:07 AM
Re: WiFi not working
@Gabby1231 wrote:Hi my WiFi keeps going off for days at a time when the heatwave is here - I have turned it on/off it is not in direct sun/heat and the engineer came last week but it was currently working at this time so couldn't see the problem
Are you getting any lights on the hub that confirm the wifi is off rather than just a weak wifi signal?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
