Discussion topic: Flood limit reached
This message was authored by: LionelO
Flood limit reached
What does flood limit reached mean ?
Re: Flood limit reached
@LionelO
In context of the forum it usually means you've tried to post the same post more than once
Avatar for LionelO
Sadly it is nothing to do with posting anything
@LionelO
Could you give more context to getting that message
If you are talking about a router, then the firewall has temporarily blocked a particular address because it is flooding you with traffic and possibly going to crash the router.  This is most likely to be a fault but it could possibly be a deliberate Denial of Service attack.
@LionelO
That you're temporarily underwater?
This message was authored by: Me134
@cookiemonsteruk wrote:
@LionelO
Hmm, just got this message myself after I thought I'd already replied to a broadband post. I tried again and got:-
Correct the highlighted errors and try again.
  • Maximum flood limit reached.
https://helpforum.sky.com/t5/Broadband/Wifi-trouble/m-p/5315813#M577394
Not a Sky employee
Sky FTTP 500Mb to Max Hub
