Discussion topic: Nighthawk AC3200 WiFi Router (R8000) not working
This message was authored by TheMillkman This message was authored by: TheMillkman
Hi,
I  have just had Sky Fibre (500gb) installed and Sky router is terrible. I want to use my Nighthawk router.
The same router worked fine with Hyperoptics
Do you know if it's compatible?
https://www.netgear.com/home/wifi/routers/r8000/
This message was authored by mae-3 This message was authored by: mae-3
Re: Nighthawk AC3200 WiFi Router (R8000) not working
@TheMillkman
The Netgear R8000 doesn't appear to support DHCP Option 61 client identifier for authenticating with Sky broadband but it may work by setting up DHCPv6 Prefix Delegation (PD) which works on about 80% of Sky broadband exchanges.
Alternatively, you could set it up connected to the Sky router by ethernet on one of the LAN ports and set it to wireless Access Point (AP) mode.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
