Discussion topic: New sky hub does not work
This message was authored by: CharlChil
I moved into my property two weeks ago and ordered Sky Broadband. I received the equipment and my activation date was midnight on 05/05/2026.
My setup is straightforward: I have no phone box, only a wall-mounted ONT. I have connected the yellow/black ethernet cable from Port 4 on the Sky Hub directly to the ONT's ethernet port, exactly as instructed in the printed documentation provided.
Despite this, the Hub consistently shows a red light. The ONT itself shows no light on the LAN port, though the power and PON lights are green.
I have now contacted Sky Technical Support three times. The first two advisors confirmed everything appeared correct on their end and advised me to power everything off for 30 minutes — which I did, with no result. The third advisor, contacted 36 hours after the activation date/time, told me the line is in a "pre-active state" and to try again tomorrow. This is not an acceptable resolution.
I have followed every instruction — both from your support team and the printed documentation — to the letter. The problem has not moved forward in 36 hours.
I am formally putting Sky on notice: if this is not fully resolved by tomorrow, I will be exercising my right to terminate this contract within the cooling-off period. I expect a prompt, substantive response — not another instruction to wait and try again.
Re: New sky hub does not work
You are only talking to other customers here and not Sky support so if you want to terminate your contract you will have to call them again in the morning.
