Discussion topic: New router won’t allow me to stream Rouvy
Message posted on 12 Jan 2025 02:40 PM
Use Rouvy (cycle streaming App) regularly. No problem before change to fibre broadband. Now App keeps telling me a firewall is blocking streaming. This is on an IPad Pro that does not have a firewall.. can only run the app using personal hotspot from mobile. Can't work out what the problem is.
Message posted on 13 Jan 2025 10:38 AM
Re: New router won’t allow me to stream Rouvy
Message posted on 23 Apr 2025 11:35 PM
I have exactly the same problem.
Using iPad Pro, which works fine if I link it to my mobile over 4G
can you tell me how this was resolved or could support get in touch with me?
Message posted on 24 Apr 2025 07:44 AM
@Marcobraynio you can get issues with some services with Apple's privacy settings so check for differences like having the private wifi address setting or using Apple Cloud private relay. Check the settings for the Sky connection.
Message posted on 24 Apr 2025 08:55 AM
Thanks for coming back to me.
I don't have any privacy settings such as private wifi set up and it isn't a wifi issue. I am connected to the router. It is the broadband connection that drops WAN not LAN.
Message posted on 26 Sep 2025 01:02 PM
Having exactly the same issue can someone please advise how to get around it.
