Discussion topic: New hub
This message was authored by: Chrisstocky
New hub
Need a new hub sent out been without Internet for 3 days now and have made 3 phone calls without any help
Re: New hub
@Chrisstocky
What's the issue that makes you believe a replacement hub is the solution?
Re: New hub
@Chrisstocky So do you know if one is on it's way to you, looking at your orders you would expect to see it attached unless the sky CS tested and did not consider it a hub fault but after 3 conversations by now would expect you have the correct info!
Avatar for Chrisstocky
Level 0 icon
Re: New hub
No power going to the hub and no lights on the hub when plugged in would suggest that the hub is broken.
Re: New hub
@Chrisstocky Have you looked at the rest now, or do you trust CS has it sent out to you, may just be the PSU unit faulty!
