1
This discussion topic has been answered Discussion topic: New Fibre Broadband
This message was authored by: Pat2711
New Fibre Broadband
Sky have offered me a free upgrade to full fibre broadband but this will mean the router will have to move from beside my only tv to another room. Will it be able to connect wirelessly with my tv or should I decline the offer?
This message was authored by: Waveman Answer
Re: New Fibre Broadband
Provided you TV has Wi-Fi it should be able to connect to the router they send you. A lot depends on the type of house you have and how it is constructed. Can you get Wi-Fi on a tablet/phone/laptop in the place that the new router will be located? If you can then it will probably work.
Wi-Fi struggles to get through stone and brick, and some houses are internally walled with board that has a foil on the back, which will also stop Wi-Fi in its tracks.
If you currently connect your TV using a Ethernet cable to your router then you could use TP Link Powerline devices to keep this arrangment. The adapters plug into your mains sockets and send the data over your mains to wherver you need it.
Alternativly you could run a long ethernet cable from your routers new position to your TV.
Unfortunatly without trying it you won't really know.
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
