Discussion topic: Network set up
This message was authored by: MJG1968
Network set up
I have a new white Sky Q router but it keeps cutting dropping from the internet. I go to Network Set Up, do the set up eg press WOS button on router but it will not connect. I have switched off everything and restarted. Getting fed up as cannotnaccess apps via TV. It was not a problem with the black / old Sky Q box
Re: Network set up
@MJG1968  There is no White Sky Q hub, what you have is the Sky Max hub.
