Discussion topic: Network connection
Message posted on 19 Apr 2025 02:23 PM
Network connection
No network connection, read + tried everything but still no connection to TV
Message posted on 19 Apr 2025 02:33 PM
Re: Network connection
Hi,
How are you connecting to the TV is this via ethernet or Wifi?
What have you tried so far as this will help.
Are any other devices able to connect.
What router do you have.
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
Message posted on 19 Apr 2025 05:51 PM
Hi
I'm using WIFI to connect to TV with max hub. I've done all they advised on web/TV to reconnect (push WPS, turn on/off) + I've refreshed connect on TV itself. As said tried several times to get connected but just keeps kicking me back to "no connection" on sky page
Message posted on 19 Apr 2025 07:29 PM
What lights do you have on the front of the router,
Can you check here under broadband and report back.
https://www.sky.com/servicestatus
