Discussion topic: Network connection. There is a problem with Network connection
This message was authored by: Sesaw
I have no network  connection, been trying to connect and set up. My son is studying  for his GCSE and no Internet since this afternoon
Re: Network connection. There is a problem with Network connection
@Sesaw
