Discussion topic: No Wifi
This message was authored by: Ptaaffe
No Wifi
Hi,
Our internet has randomly disconnected and we can't get it back on! There are 2 orange lights on our box, we have tried reconnecting the grey wire,resetting the box etc and unplugged wifi extenders too and nothing is working. When we try and test it via the sky website it says nothing is wrong with it although no device can connect and on my phone it even says no internet connection! It says there are no outages either.
Re: No Wifi
@Ptaaffe
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't returned by 7am use the below link to check to see if there are any broadband problems or outages nearby
