This discussion topic has been answered Discussion topic: The connection drops every few minutes for about 30 seconds
Message posted on 31 Mar 2025 11:59 AM
The connection drops every few minutes for about 30 seconds. As a result zoom and teams calls are impossible.
When I do a service checker I get "looks good" as result.
I switched from BT a couple of days ago. I had no problems with BT.
Message posted on 31 Mar 2025 07:14 PM
I believe I have solved the problem by swapping the router for another one.
ChatGPT came up with some good diagnostic tests:
open a command window ad enter:
ping -n 100 8.8.8.8
also try:
pathping 8.8.8.8
If possible test a wifi connected PC as well as an ethernet connected PC
If possibl etry testing both at the same time
Message posted on 31 Mar 2025 01:36 PM
							Re: The connection drops every few minutes for about 30 seconds
You could try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Message posted on 31 Mar 2025 01:40 PM
As I mentioned in my first post, I tried the service test and it said "looks good", but that is wrong.
It might be fine at a particlar instant when the test it done, but it is not continuously good. It is a disaster for video calls.
Message posted on 31 Mar 2025 01:46 PM
Then as suggested you will have to call Sky about this.
150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
Try saying nothing when spoken to by the bot.
ping -n 100 8.8.8.8
also try:
pathping 8.8.8.8
Message posted on 03 Apr 2025 01:18 AM
I discovered the root problem. In my netwrok I had several other routers including an old sky router. Because I switched from BT to Sky recently in turns out that having 2 sky routers connected was causing problems. Removing the old Sky router from my LAN solved the problem.
