05 Feb 2024 12:40 PM
Hi
Can I use this router straight with OR modem ? So bypassing sky router ?
If yes, what settings do I need to enter into Netgear please ? It has got better parental controls.
Thanks xx
06 Feb 2024 10:40 AM
Posted by a Superuser, not a Sky employee. Find out moreIf you have Ultrafast with an Openreach ONT then you should be able to use it without the Sky hub in place.
Simply type abc123@skydsl|abc123 into the client identifier box at the bottom of the WAN settings.
06 Feb 2024 11:07 AM
Thanks I will try that today. And no need for DHCP and some number like 61 ?
Yes I am using ultrafast and ONT.
06 Feb 2024 11:08 AM
Posted by a Superuser, not a Sky employee. Find out moreThe client identifier box is the DHCP Option 61 area you are referring to, they have different names but do the same thing.
07 Feb 2024 01:27 PM
I am totally lost I don't know where to find these settings in Netgear interface. Attaching few snapshots if it helps please
07 Feb 2024 05:31 PM
Login into the router interface->Basic Tab and select the internet option at the bottom. There is an insert option and in that place, you can set up DHCPv4 client identifiers, especially relevant in '61' which is where you type the 'anything@skydsl|anything' in option 61 once created in that setting place for DHCP Options.
07 Feb 2024 09:41 PM
Thanks Mae but this is the interface I am getting under internet and can't see any other option I am afraid
07 Feb 2024 10:13 PM
Just waiting for the screenshots to be approved.
07 Feb 2024 11:41 PM
From the screenshots, it looks like the RAXE300 does not support DHCP Option identifiers, and therefore you are out of luck with connecting that Netgear router to the ONT directly unless DHCPv6 PD works which is only present on approx 80% of Sky broadband exchanges.
08 Feb 2024 10:04 AM
Posted by a Superuser, not a Sky employee. Find out moreAre you sure its not under the advanced tab?
Also have you upgraded the router to the latest firmware first?
08 Feb 2024 10:14 AM
Firmware up to date
it's not there as per my understanding. Sky is not giving me any dsl username or password. Asked Netgear. They said it's compatible and can be connected to OR ONT.
sharing some screen shots
08 Feb 2024 10:19 AM
Posted by a Superuser, not a Sky employee. Find out moreSky wont give you your username & password because they do not exisit. It is simply a client identifier string of abc123@skydsl|abc123
08 Feb 2024 10:31 AM
Oh I see
But where to enter that string ? Asked Netgear support. They assured it can be connected direct.
Also network cable from OR ONT will go into my Lan port or Internet port ?
08 Feb 2024 10:35 AM
Posted by a Superuser, not a Sky employee. Find out moreI dont know, I am not familiar with that router but it will have to be in the Internet/WAN settings if it exists.
You should ask Netgear specifically where the DHCP Option 61 or Client identifier string box is.
08 Feb 2024 12:42 PM
@dejavu94 wrote:Hi
Thanks xx
I've been through the manual for the RAXE300 and I cannot see any reference for Opt61 at all, whereas the RAX70, which I have has. Whilst researching the Netgear products I found that some of their routers support this option but some don't. Haven't a clue why...
