5
Discussion topic: Need to move router across the room. Broadband cable to short.
This message was authored by FAP06 This message was authored by: FAP06
New broadband installed today with 4.2 router. I need to move my router across the room or alternative put it on a shelve but the ethernet cable that came with the router is very short. The engineer said i must get an WAN cable and a ethernet cable wont work from the wall socket to the router. Unless i missed something looking on line i only get ethernet cables cat 6,7 or 8. Can someone please help as i dont want to get the wrong cable and would preffer to connect my Sky Glass by cable rather than WIFI?
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: Need to move router across the room. Broadband cable to short.
@FAP06
If your broadband is full fibre with an ONT then a cat 5e rj45 to rj45 ethernet cable will do the job
@FAP06
FAP06
Yes i have full fibre. Switched over from Virgin to Sky today so all setups new.. Thanks i have a cat 7 lying around will see if it works.
FAP06
Silly question whats an ONT? Learning the technical stuff.
@FAP06
Its an Optical Network Terminal
And effectively acts as a fibre optic modem turning light signals into electric signals
FAP06
Thanks for the help. Yes one of those were newly installed aswell. Ill have a look later and see how it goes.
