Discussion topic: Need network t
This message was authored by: Katecoin
Need network t
New broadband user ff. need Network name as still old network showing.  Despite reading a million times it's on the router it's not.  Beginning to wonder if I should have changed from Plusnet. Also need Some number
Re: Need network t
@Katecoin The setup guide electronic version linked below!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Re: Need network t
@Katecoin if you have Sky Q boxes then you will still see the old network name ignore that you need the new one. If Sky have swapped a white Sky Max hub for a new one they will have applied a switch somthe network details matched the old hub simplifying the change over so it should be plug and play.
