Discussion topic: Connection issue - Citrix Workspace - WFH - VPN - New Hub Blocking connections / Firewall?
This message was authored by Darryl450 This message was authored by: Darryl450
Hi,
I require urgent assistance with my issue.
I'm a new customer to Sky with a brand new hub but I'm having an issue with my work laptop connectivity, specifically connecting to Citrix which allows me to use my works remote desktops etc.
I have tried every single change to the router settings that I've found on this forum to which it still will not work.
Such as UPnP, DMZ, firewalls off, IPv6 off, using WPA2 security, MAP-T Sharing Ratio: showing as 1:1, broadband shield disabled
What more can I do?
I have found that connecting directly from my Openreach ONT via WAN ethernet into my Cisco device that it allows me to  get onto my work network and Citrix works fine. But that means I don't have any Wifi/connectivity at home to other devices. It just will not work via the Sky Hub. This proves that it's the hub blocking connections somehow.
I have called and been told it's being looked at however I need this looked at asap as I work from home. I have also filled out the VPN issues form that I stumbled across.
If anyone can please escalate this matter I would be very greatful. I feel I have tried all I can my side and investigated when I shouldn't have to go through this as a new customer. Overdid the name in the title to make it aware for others once a solution is found.
Re: Connection issue - Citrix Workspace - WFH - VPN - New Hub Blocking connections / Firewall?
@Darryl450
The issue is almost certainly the Sky implementation of Map-T on the Max Hub: unfortunately changing the mapping to 1:1 doesn't appear to resolve it.
Darryl450
Thanks for the response however I need this fixed.
Are you able to escalate this for me?
I'd be very greatful.
This message was authored by Tom-W19 This message was authored by: Tom-W19
Posted by a Sky employee
Hi @Darryl450
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
This message was authored by Thomas9797 This message was authored by: Thomas9797
I am having a similar issue with this and would like to know how this has been resolved please.
@Thomas9797 the specific issue applies to the white Sky Max hub and in some cases can becresolved by implementing UPnP as explained here UPnP set up
If that does not work for you complete this form https://forms.office.com/e/kk1gCkWsRb?origin=lprLink
This message was authored by Addie15 This message was authored by: Addie15
Update-We are closing this session now due to no further response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
Darryl450
Still no solution as of yet. I've tried all the suggested setting changes. I don't have time to wait for the results of a form when I need it for work. Second hand previous gen hub is on the way to me, I'll use that instead.
Darryl450
Just to finalise this topic, the issue has been resolved by Sky Network Team by disabling MAP-T entirely.
Thank you to all involved.
This message was authored by KAVITHA123 This message was authored by: KAVITHA123
I have been having the same issue for weeks also and filled that ms form in but heard nothing and the sky helpline couldn't solve. Is this now fixed for everyone using this new white box or does it require a case by case fix? Can someone help sort mine also if needed?
thanks
Re: Citrix BYOD Remote Desktop blocked
Please can mine be sorted by Sky tec team like it was for a similar customer in post here:
appears Sky tech team   has been resolved by Sky Network Team by disabling MAP-T entirely.
 https://helpforum.sky.com/t5/Broadband/Connection-issue-Citrix-Workspace-WFH-VPN-New-Hub-Blocking-co...
@KAVITHA123 we are advised a potential fix is under review but currently it is still case by case as far as I am aware. The team handling the forms are not customer facing and have other duties. If you submitted the form in the last couple of weeks you could be in the queue as people are on holiday.
I am escalating your post to the Sky team who support the forum who should be in touch soon to offer you a private online chat session to see if they can get you any information. Keep an eye on the forum as if you miss the message just click the brightly coloured chat icon which will be added to the forum pages for you to use.saving a long phone call.
This message was authored by Mr+Flibbles+86 This message was authored by: Mr+Flibbles+86
Thanks for escalating this. We’ve sent an invite to chat.
