Discussion topic: My wifi isnt working
This message was authored by: Ali62
My WiFi has just decided not to work in the essex area I've checked connections on the app & it said it looks good. It's showing 2 green lights & 2 orange.
Re: My wifi isnt working
@Ali62 the test result you saw is from when the test last ran routinely click to test again it will tell you the current position.
