Discussion topic: WI-FI Connectivity
Message posted on 28 May 2024 07:14 PM
WI-FI Connectivity
Since having Sky Broadband installed on 13th May our WIFI signal has deteriorated compared to our previous provider. With devious struggling to connect via WiFi.
Message posted on 29 May 2024 07:42 AM
Re: WI-FI Connectivity
@RyanG81 wifi coverage does vary as it depends onnthe location of the Sky hub, the layout and type of construction of your home and the level of interference. Sky do not provide extenders unless customers have bought either the Broadband Boost or Wifi Max bundles or have Sky Q boxes which dont connect. Sky hubs have pretty similar performance to other ISPs routers.
Check that your hub is in the best position it can be which is on a shelf or a surface well above onstructions like radiators. If you are still stuck call Sky but be warned they will try and sell you an add-on or consider buying third party wifi kit.
